Glashutte Original Spezimatic divers
Looks like they just did a remake of the Spezimatic divers. So if you like really large numerals, you must be excited. Vintage pic above, new ones here:
https://www.glashuette-original.com/spe ... collection
Re: Glashutte Original Spezimatic divers
Not something I'd expect from GO but kind of interesting. I get the vintage roots, but a bit small for a diver at 39mm IMHO. I'm a big GO fan so curious to see them in person.
Love the big date on Glashütte. Not sure it works on these new ones
Where are yo I seeing 39mm?
This one looks great.
https://www.glashuette-original.com/col ... 3-02-81-70
It’s 43mm.
The versions without the big date (which are closest in design to the original) are 39.5mm.JP Chestnut wrote: ↑Fri May 17, 2019 4:09 amWhere are yo I seeing 39mm?
It’s 43mm.
https://www.glashuette-original.com/col ... 1-01-80-08
Don't love the big date on these.
Interesting. The case is reminiscent of the Seiko 62MAS. I like the fact they color matched the date wheels.
The 4 o’clock date window location isn’t great, but I think it’s cool that they squared it instead of the more typical angled numbers. It’s different and purposeful. I just need to get used to it.
That’s a lot less good looking.logan2z wrote: ↑Fri May 17, 2019 4:18 amThe versions without the big date (which are closest in design to the original) are 39.5mm.JP Chestnut wrote: ↑Fri May 17, 2019 4:09 amWhere are yo I seeing 39mm?
It’s 43mm.
9,700 Euro on bracelet. Makes me like my SLA017 all the more.JP Chestnut wrote: ↑Fri May 17, 2019 4:46 amThat’s a lot less good looking.logan2z wrote: ↑Fri May 17, 2019 4:18 amThe versions without the big date (which are closest in design to the original) are 39.5mm.JP Chestnut wrote: ↑Fri May 17, 2019 4:09 amWhere are yo I seeing 39mm?
It’s 43mm.
The 39.5 model is a LE of about 50 if I read correctly. The regular model looks different and is 43.
Only the '1969' model, that most closely replicates the original, is an LE. The other 39.5mm models are not.
https://www.glashuette-original.com/col ... 1-06-80-08
The SLA017 is one of the few Seikos I like, but I think the comparison is apples and oranges.Ryeguy wrote: ↑Fri May 17, 2019 6:08 am9,700 Euro on bracelet. Makes me like my SLA017 all the more.JP Chestnut wrote: ↑Fri May 17, 2019 4:46 amThat’s a lot less good looking.logan2z wrote: ↑Fri May 17, 2019 4:18 amThe versions without the big date (which are closest in design to the original) are 39.5mm.JP Chestnut wrote: ↑Fri May 17, 2019 4:09 amWhere are yo I seeing 39mm?
It’s 43mm.
I don't know enough about the 39-11 movement to argue that point, but both are visually similar, limited edition, stainless steel sport / dive watches. They have identical water resistance and nearly identical dimensions. Vastly differing price points.logan2z wrote: ↑Fri May 17, 2019 7:24 amThe SLA017 is one of the few Seikos I like, but I think the comparison is apples and oranges.Ryeguy wrote: ↑Fri May 17, 2019 6:08 am9,700 Euro on bracelet. Makes me like my SLA017 all the more.JP Chestnut wrote: ↑Fri May 17, 2019 4:46 amThat’s a lot less good looking.logan2z wrote: ↑Fri May 17, 2019 4:18 amThe versions without the big date (which are closest in design to the original) are 39.5mm.JP Chestnut wrote: ↑Fri May 17, 2019 4:09 amWhere are yo I seeing 39mm?
It’s 43mm.
I don't want to come across as one of those "my Seiko is a good as your Rolex" guys, but I couldn't help but notice the visual similarities (Arabic numerals aside).
(If I were one of those guys I might also point out that Seiko produced their 6217 4 years prior to GO releasing their Spezimatic diver, so there is the possibility the Seiko influenced the GO design.)
Point taken, there are many visual similarities.Ryeguy wrote: ↑Fri May 17, 2019 8:19 amI don't know enough about the 39-11 movement to argue that point, but both are visually similar, limited edition, stainless steel sport / dive watches. They have identical water resistance and nearly identical dimensions. Vastly differing price points.logan2z wrote: ↑Fri May 17, 2019 7:24 amThe SLA017 is one of the few Seikos I like, but I think the comparison is apples and oranges.Ryeguy wrote: ↑Fri May 17, 2019 6:08 am9,700 Euro on bracelet. Makes me like my SLA017 all the more.JP Chestnut wrote: ↑Fri May 17, 2019 4:46 amThat’s a lot less good looking.logan2z wrote: ↑Fri May 17, 2019 4:18 amThe versions without the big date (which are closest in design to the original) are 39.5mm.JP Chestnut wrote: ↑Fri May 17, 2019 4:09 amWhere are yo I seeing 39mm?
It’s 43mm.
My experience with GOs tells me that they're very finely made/finished watches. The movements are finished to a high standard, dials and cases are made in-house and beautifully done, etc. I don't have the same experience with Seikos but my understanding is that, with the possible exception of Grand Seikos, they are not at the same level - nor would I expect them to be given the disparity in price points. That said, I'm not in love with this particular GO and wouldn't drop $10K on it.
I agree 100%. Again, I was just taken with the visual similarities between the two.
In reality, we could probably find a dozen other models from this era with similar case designs. Like most things in watch making, the devil is in the details (and therefore the price premium).
I actually like this GO. I don’t $10K like it, but if I rolled in the income bracket where a $10K purchase was an “impulse buy”, I’d probably hit it.
I'm sure the GO is made to a nicer standard, but I think the Seiko is probably a little better looking.
So the 39.5 LE is 9,700 euros.....how much is the regular production 39.5 size?
- demer03
I like it. A lot.
One word of caution to a serial flipper like yourself: While great watches, GOs can take a real beating on the secondary market.rockmastermike wrote: ↑Fri May 17, 2019 9:15 amYep - has me contemplating things (depending on price)
They're all 8,500-8,800 Euros on strap (depending on buckle). The non-LE is available on bracelet for 9,700 Euros.rockmastermike wrote: ↑Fri May 17, 2019 8:57 amSo the 39.5 LE is 9,700 euros.....how much is the regular production 39.5 size?
- demer03
You know me...stuck in the vintage. It ticks my boxes but I can see your point.
Users browsing this forum: mattcantwin, raf42, shaneotool, tmw and 1371 guests
