Damasko DC86
- spring-diver
- Name: Shannon
Damasko DC86
Just released! This is pretty cool
All photos and information from stuffler, mike @ WUS
There will be a orange accented version coming soon.
I’m really digging this one below
Specifications.
DAMASKO CHRONOGRAPH DC 86 BLACK
Movement:
Damasko automatic caliber C51-6 (based on ETA 7750), Ø 30.4 mm, height 8 mm; 29 jewels; 28,800 a / h; Power reserve 48 hour
Functions:
Hours, Minutes, Small Seconds; Chronograph with center seconds, minute and small hour counter, additional 24-hour display, date indication
Case:
Ice-hardened stainless steel with Damest coating, Ø 42 mm, height 13,9 mm; solid screwed back, screw-in crown, integrated magnetic field protection, wr 10atm
Crystal:
Domed sapphire crystal, anti-reflected coating on the inside
Bezel:
The bezel is available in different variations: hours 1 to 11; classic minute scale from 5 to 55; a countdown bezel; one directional diver's bezel
Strap:
Leather with pin buckle
Retail:
€ 3580, - (on strap)
It was a long path of try and tribulation: After a first implementation in modular design, it became clear that an integrated chronograph mechanism would be the better option. Thus, 2013 began with the work on a corresponding caliber. The base movement chosen again was the proven chrono movement ETA 7750.
After four years of development work in-house, they were on target in 2017 and presented the caliber C51. The focus point of the redesign was the jumping minute stop hand, for which a new mechanism was constructed, involving, among other things, five additional gears.
The new C51 movement in the DC 80 chronograph had its premiere, dispensing entirely with auxiliary dials and concentrating on the seconds and minutes counters from the center.
But the caliber C51 can do a lot more. Thanks to the integrated chronograph mechanism, it is possible to place a date disc directly under the dial - not implemented deep inro the movement, as with some modular constructions. And the free space on the dial can be used for other ads, such as the display of a second time zone.
After the chronograph DC 82 with stop minute hand and date display, the model DC 86 now appears as the next sequel. The DC 86 is equipped with the Damasko caliber C51-6, which in addition to the stop second and minute out of the middle also counts the hours - on a sub-dial at «6». At «9» you will find the small second, while at «3» there is an additional 24-hour display, which always moves in the same way as the main time.
The display of stop seconds and minutes out of the center is a benefit to readability supported by the color scheme: all chronograph functions are „green“, the fully colored seconds hand and the minute hand with a green tip (plane silhouette) as well as the index and hand of the hour sub counter at the «6».
Thoughts?
Shannon
Sent from my iPad Pro using Tapatalk
Specifications.
Movement:
Functions:
Case:
Crystal:
Bezel:
Strap:
Retail:
Thoughts?
Shannon
Re: Damasko DC86
I want to love it. I don’t, though.
Re: Damasko DC86
It's actually pretty cool and works very well in real life.
"The watch case is made in-house by Damasko and features the industry's toughest material yet. The material is called ""ice-hardened, nickel-free stainless steel"". What is so unique about this steel is that they are absolutely nickel-free, offer a good corrosion resistance, and can be tempered up to 64 HRC/800Vickers which is four times the hardness of every other steel currently used in the watch industry. And this ice-hardened steel is used for the entire case, crown and pushers.
While other manufacturers choose to harden the surface of 316L (1.4435) or 1.4301 up to 1200 Vickers by diffusing carbon into the top layers of the steel, there is no way to temper the material. Due to the austenitic structure of the alloy it is impossible to make sure that that steel remains its hardness throughout the body.
Various tests have proved that this kind of surface treatment is not suitable for our purposes because it only hardens the top layer of the metal. This leads to the so-called eggshell effect. We were able to dent and scratch the “hardened” surface with an ordinary pair of tweezers (which are normally made from spring steel) because the material underneath the hard layer was not able to withstand the pressure."
- poppydog
- aka Nelldog
- Name: Steve
Re: Damasko DC86
Thanks ToddChocodove wrote: ↑Mon Oct 28, 2019 12:38 pmIt's actually pretty cool and works very well in real life.
Steve
Steve
- 1954Selmer
- Name: RC
Re: Damasko DC86
I sold my Damasko a long time ago and I wish it would walk back through my door. They make some cool shit.
Re: Damasko DC86
The green is shit, but the other one is cool in an austere way.
- tattoo chef
- <Will Skull for Food>
- Name: Don
Re: Damasko DC86
I really like it overall, but hate the date placement.
Re: Damasko DC86
Agreed. Love the design but why couldn’t they just make it a no date instead?tattoo chef wrote:I really like it overall, but hate the date placement.
Re: Damasko DC86
Seeing a plane on the one hand there Shannon. So I like it !
Always like it on vintage watches too, and just the way that
Damasko implemented it. Even the look of the registers, and
sub-dials is great imho.
Some real home runs from them. Thanks very very much !!
Users browsing this forum: AdnanS2024, Google [Bot], sub600 and 295 guests
