65' VW Bug project
Re: 65' VW Bug project
Looking sharp! Nice work.
You're inspiring me to get the Alfa back on the road.
Greg
My daughter and I dropped the engine to do come clean up work. We are also putting in a later model transmission for lower rpms while cruising the highway.
I have new shocks, engine tar board insulation, clean up more wiring, and reseal the engine.
Good times.
Good times.
- Name: Geoff B
Cool ride cant wait to see even more pics
- JDC222
- Demander of Intro Threads
You need this 2176cc in there!!
- unixshrk
- This. Truth.
- Name: Chris
Nice!!JDC222 wrote:You need this 2176cc in there!!
I found some brass German spades and multiple sizes of loom sheathing today at a local electronics wholesaler. Unfortunately I found out he is retiring and closing shop after 33 years.
cool motor. to much for this guy though. maybe at a later date
I had a question about the German spade connectors on why they are better than the regular style. Most of the ones you can buy at an auto parts store are cheap aluminium ones that corroded really easily and do not fit as tight as the brass german version. The other issue is the style of connector they are. When you crimp the aluminium versions they usually only have one center section that is crimped. This is not enough unless you also solder them. The german style actually has two sets of ears that crimp down into a U shape. The first set crimps into the stranded wire and the second set crimp down into the insulation.toxicavenger wrote: ↑Sat Oct 19, 2019 4:13 pmI found some brass German spades and multiple sizes of loom sheathing today at a local electronics wholesaler. Unfortunately I found out he is retiring and closing shop after 33 years.
I know everyone has their ideas on whats best but for me the german style seems to have more longevity to them. Since I will be fixing/cleaning up the rest of the wiring on the VW I want to do right so I do pay for it later.
The loom sheathing I got today is almost like heat shrink tubing. It is the same style that came on a lot of older german cars. It is a solid piece without a split down the side. It is a very durable product. It can tougher to troubleshoot bad wiring with this solid style of sheathing, but protects the wiring and isn't as bulky as other versions on the market. Since this wiring will be routed behind the engine tar board (insulation) I need to use the best stuff I can.
Here are some pics I stole offline that I have modded with info.
Local electronics wholesaler. Don’t see many of that kind of shop anymore.
I wish I had your car skills, T. That looks like a lot of fun. It’s great you are doing this with your daughter. Those hands-on craft skills aren’t being learned by very many in the recent generation.
I forgot to post this pic. I had my buddy rebuild a rear fender for me since the last one was shredded when a tire blew out in the 80-90's. The previous owner never got around to fixing it. I am not a body working guy but I did weld up all the holes from the accident and skim it with a little putty. The paint job on this car is about 30 years old so I tried to find something that will match it. I have not sprayed any clear on that area yet but I did mount the finished fender and welded in two new fender nuts.
My daughter is helping out. She isn't really sure if she wants to. And I totally get it with her being a teenage. But hopefully she learns something from it. One thing is she likes to tinker, so that is always a plus.HapaHapa wrote: ↑Sat Oct 19, 2019 8:50 pmLocal electronics wholesaler. Don’t see many of that kind of shop anymore.
Car skills? I can tear one apart that is for sure.
- Henryj
- Bubblehead
- Name: Old guy
Outta curiosity, what model Alfa? I took on a ‘69 GTV 1750 project a long while back. Apparently, Marelli is Italian for “Lucas rejects”.
“Punishable by fine” = Legal for a price.”
I started removing the cooling tins from the engine and I found a pretty big rats nest on each side of the engine. This had to be obstructing the cooling of the engine some. Not many leaks on the engine except for the front engine seal area. When the flywheel was removed (I didn't have the tools so my Porsche buddy did that part) we found out the flywheel seal had harden to the point that is was also leaking. I also broke a few exhaust bolts so I will change them all out. I will also install a new exhaust gaskets on the engine.
Pics of the nest.
Pics of the nest.
I am always impressed with people that can do stuff like this. Thanks for the updates T.
- JDC222
Hey Terry, while you have everything out and apart, consider relocating the fuel filter from the engine bay to the underside of the car, near the gearbox, where the hard line comes out of the tunnel. Make sure it’s secured, so it doesn’t bounce around. Also, make sure you install it in the correct orientation, so that the flow of the fuel matches the flow arrow on the filter...Many engine fires could have been prevented, if the fuel filter wasn’t mounted over the engine.
Looking great so far buddy!!
Dave thanks for the suggestion. The previous owner had some cheap fuel line on it. So I changed it all out with german cloth braided line and put a Hastings metal filter above the drivers side rear tire. Next I will clean the tank out really good on it and change the tank filter.JDC222 wrote: ↑Mon Oct 21, 2019 8:02 amHey Terry, while you have everything out and apart, consider relocating the fuel filter from the engine bay to the underside of the car, near the gearbox, where the hard line comes out of the tunnel. Make sure it’s secured, so it doesn’t bounce around. Also, make sure you install it in the correct orientation, so that the flow of the fuel matches the flow arrow on the filter...Many engine fires could have been prevented, if the fuel filter wasn’t mounted over the engine.
A few updates. I cleaned the package area under the Bug. The undercoating was hiding some surface rust. Since the car is meant to be a daily driver now frame off crazy $15k restorations.
I brushed on Rust-Oleum to cover the metal up. The are better options at higher cost. But with the way things are I am trying to not spend as much.
All of the engine tin I sandblasted and painted. The new to me transmission is cleaned and I rebuild the throw out bearing.
Next is to get the transmission installed and motor resealed with new gaskets. It ran good already but it does has some leaks.
Do you have a small sand / media blaster at home?
There are so many times I've worked on stuff and wished I had a small blasting cabinet to knock the surface rust / old paint off stuff.
Another option is to pickle the rusted parts. Just toss them into a bucket of vinegar for a weekend or so. The acid will take off the rust and leave you surface you can paint. There are some Youtube videos on pickling rusted parts.
There are also chemicals you can use to soak off the rust, but they can be dangerous to use without proper safety precautions.
I have a cheap portable sand blaster my Dad bought me about 8 years ago from Harbor Freight. https://www.harborfreight.com/portable- ... 37025.html I also have an Air Needle Scaler that does a great job on loose rust.Ryeguy wrote: ↑Thu Nov 14, 2019 10:10 amDo you have a small sand / media blaster at home?
I sometimes use paint remover but I do not like having all those chemicals around the house.
This is all awesome.
I believe molasses also works for removing rust but it may take longerRyeguy wrote: ↑Thu Nov 14, 2019 10:10 amDo you have a small sand / media blaster at home?
I’ve not heard that one, but getting rid of a bunch of old molasses seems like a potentially nasty task, not to mention the bugs and critters a pile of molasses would attract if left out over a weekend.
I may pick up one of those cheap blasters. I’ve got some boat trailer parts (fender hangers, etc.) I’d like to clean up. $30 and some quality time with a blaster and a rattle can of Rust-oleum beats $250 worth of new parts.
Phosphoric acid (naval jelly) converts rust to a material that can be painted over.
I use to use naval jelly when I lived on the east coast and worked on cars more frequently. That shit is rough, especially if you get it on your hands. Here most of what I have is rust scaling. So I just clean it up a bit and then use Rustoleum. I use to use POR15 but the uv rays where turning it to crap.
I have had better luck using brush on rustoleum. It seems to coat thicker. I wipe everything off really well with brake kleen or acetone before painting.
Oh get good blasting sand. Play sand does not work worth a shit.
Users browsing this forum: No registered users and 197 guests
