https://www.google.com/search?q=subaru+ ... CA0&uact=5JP Chestnut wrote: ↑Tue Mar 23, 2021 8:21 amHere you go.manitoujoe wrote: ↑Tue Mar 23, 2021 8:13 amI’ve owned nothing but Subaru Foresters from 2006. Never had a single issue. Best cars I’ve ever owned, bar none. I haven’t seen or heard of any issues.toxicavenger wrote:well the 90's and early 2000's were horrible for subabru. they had headgasket issues for 10 year son most of their models. unfortunately i owned a few of them that did the same thing. so i think the rebranding was to try and gather up more steam to fix a car that could be better than it currently was.
https://www.google.com/search?q=subaru+ ... 0&bih=1058
2021 Ford Bronco Release - 7/13
Re: 2021 Ford Bronco Release - 7/13
Nightmaretoxicavenger wrote: ↑Tue Mar 23, 2021 2:20 pmhttps://www.google.com/search?q=subaru+ ... CA0&uact=5JP Chestnut wrote: ↑Tue Mar 23, 2021 8:21 amHere you go.manitoujoe wrote: ↑Tue Mar 23, 2021 8:13 amI’ve owned nothing but Subaru Foresters from 2006. Never had a single issue. Best cars I’ve ever owned, bar none. I haven’t seen or heard of any issues.toxicavenger wrote:well the 90's and early 2000's were horrible for subabru. they had headgasket issues for 10 year son most of their models. unfortunately i owned a few of them that did the same thing. so i think the rebranding was to try and gather up more steam to fix a car that could be better than it currently was.
it was. i had 2 cars under 60k that needed over $3k of work. every time i bring it up my wife get's pissed.HapaHapa wrote: ↑Tue Mar 23, 2021 8:44 pmNightmaretoxicavenger wrote: ↑Tue Mar 23, 2021 2:20 pmhttps://www.google.com/search?q=subaru+ ... CA0&uact=5JP Chestnut wrote: ↑Tue Mar 23, 2021 8:21 amHere you go.manitoujoe wrote: ↑Tue Mar 23, 2021 8:13 amI’ve owned nothing but Subaru Foresters from 2006. Never had a single issue. Best cars I’ve ever owned, bar none. I haven’t seen or heard of any issues.toxicavenger wrote:well the 90's and early 2000's were horrible for subabru. they had headgasket issues for 10 year son most of their models. unfortunately i owned a few of them that did the same thing. so i think the rebranding was to try and gather up more steam to fix a car that could be better than it currently was.
Head gaskets are generally a PITA but most engines you can pull the head right off the engine. The boxer jammed between the frame rails makes the job much much harder.toxicavenger wrote: ↑Wed Mar 24, 2021 5:20 amit was. i had 2 cars under 60k that needed over $3k of work. every time i bring it up my wife get's pissed.HapaHapa wrote: ↑Tue Mar 23, 2021 8:44 pmNightmaretoxicavenger wrote: ↑Tue Mar 23, 2021 2:20 pmhttps://www.google.com/search?q=subaru+ ... CA0&uact=5JP Chestnut wrote: ↑Tue Mar 23, 2021 8:21 amHere you go.manitoujoe wrote: ↑Tue Mar 23, 2021 8:13 amI’ve owned nothing but Subaru Foresters from 2006. Never had a single issue. Best cars I’ve ever owned, bar none. I haven’t seen or heard of any issues.toxicavenger wrote:well the 90's and early 2000's were horrible for subabru. they had headgasket issues for 10 year son most of their models. unfortunately i owned a few of them that did the same thing. so i think the rebranding was to try and gather up more steam to fix a car that could be better than it currently was.
you have to pull the engine to do itJP Chestnut wrote: ↑Wed Mar 24, 2021 5:28 amHead gaskets are generally a PITA but most engines you can pull the head right off the engine. The boxer jammed between the frame rails makes the job much much harder.toxicavenger wrote: ↑Wed Mar 24, 2021 5:20 amit was. i had 2 cars under 60k that needed over $3k of work. every time i bring it up my wife get's pissed.HapaHapa wrote: ↑Tue Mar 23, 2021 8:44 pmNightmaretoxicavenger wrote: ↑Tue Mar 23, 2021 2:20 pmhttps://www.google.com/search?q=subaru+ ... CA0&uact=5JP Chestnut wrote: ↑Tue Mar 23, 2021 8:21 amHere you go.manitoujoe wrote: ↑Tue Mar 23, 2021 8:13 amI’ve owned nothing but Subaru Foresters from 2006. Never had a single issue. Best cars I’ve ever owned, bar none. I haven’t seen or heard of any issues.toxicavenger wrote:well the 90's and early 2000's were horrible for subabru. they had headgasket issues for 10 year son most of their models. unfortunately i owned a few of them that did the same thing. so i think the rebranding was to try and gather up more steam to fix a car that could be better than it currently was.
That’s not a bad thing though. You’d be pulling it already to fix the spun rod bearings and shattered #4 piston.toxicavenger wrote: ↑Wed Mar 24, 2021 4:56 pmyou have to pull the engine to do itJP Chestnut wrote: ↑Wed Mar 24, 2021 5:28 amHead gaskets are generally a PITA but most engines you can pull the head right off the engine. The boxer jammed between the frame rails makes the job much much harder.toxicavenger wrote: ↑Wed Mar 24, 2021 5:20 amit was. i had 2 cars under 60k that needed over $3k of work. every time i bring it up my wife get's pissed.HapaHapa wrote: ↑Tue Mar 23, 2021 8:44 pmNightmaretoxicavenger wrote: ↑Tue Mar 23, 2021 2:20 pmhttps://www.google.com/search?q=subaru+ ... CA0&uact=5JP Chestnut wrote: ↑Tue Mar 23, 2021 8:21 amHere you go.manitoujoe wrote: ↑Tue Mar 23, 2021 8:13 amI’ve owned nothing but Subaru Foresters from 2006. Never had a single issue. Best cars I’ve ever owned, bar none. I haven’t seen or heard of any issues.toxicavenger wrote:well the 90's and early 2000's were horrible for subabru. they had headgasket issues for 10 year son most of their models. unfortunately i owned a few of them that did the same thing. so i think the rebranding was to try and gather up more steam to fix a car that could be better than it currently was.
that was an issue i think on the boosted models. mine were all natural aspirated. the oil line was huge restriction on the boosted ones. kind of like a bong with too many filters.JP Chestnut wrote: ↑Wed Mar 24, 2021 4:59 pmThat’s not a bad thing though. You’d be pulling it already to fix the spun rod bearings and shattered #4 piston.toxicavenger wrote: ↑Wed Mar 24, 2021 4:56 pmyou have to pull the engine to do itJP Chestnut wrote: ↑Wed Mar 24, 2021 5:28 amHead gaskets are generally a PITA but most engines you can pull the head right off the engine. The boxer jammed between the frame rails makes the job much much harder.toxicavenger wrote: ↑Wed Mar 24, 2021 5:20 amit was. i had 2 cars under 60k that needed over $3k of work. every time i bring it up my wife get's pissed.HapaHapa wrote: ↑Tue Mar 23, 2021 8:44 pmNightmaretoxicavenger wrote: ↑Tue Mar 23, 2021 2:20 pmhttps://www.google.com/search?q=subaru+ ... CA0&uact=5JP Chestnut wrote: ↑Tue Mar 23, 2021 8:21 amHere you go.manitoujoe wrote: ↑Tue Mar 23, 2021 8:13 amI’ve owned nothing but Subaru Foresters from 2006. Never had a single issue. Best cars I’ve ever owned, bar none. I haven’t seen or heard of any issues.toxicavenger wrote:well the 90's and early 2000's were horrible for subabru. they had headgasket issues for 10 year son most of their models. unfortunately i owned a few of them that did the same thing. so i think the rebranding was to try and gather up more steam to fix a car that could be better than it currently was.
We are way off topic on a Bronco thread.... but I think oil consumption is an issue in most boxer engine cars due to the gasket/joint being vertical. This is well known in the Porsche community and just accepted... Porsche even lists 1.6 qts of oil "consumption" per 625 miles as within spec on the 996. For the 997 they improved to 1 qt per 625 miles.JP Chestnut wrote: ↑Wed Mar 24, 2021 5:28 amHead gaskets are generally a PITA but most engines you can pull the head right off the engine. The boxer jammed between the frame rails makes the job much much harder.
I've owned Honda's, Acura's, VW's and BMW's all with vertical/inline engines and I have never had to add oil to any of them at 8-10k service intervals.
Since we’re already off topic, I’ll just leave this here
Back on topic.
https://uncrate.com/2022-maxlider-broth ... co-66-suv/
2022 Maxlider Brothers Ford Bronco 6×6 SUV
There's only one white Ford Bronco worth that much money:BlueSky wrote: ↑Thu Apr 01, 2021 9:23 amA mere 59K...
https://inventory.maxliderbros.com/vehi ... ord-bronco
There is a really good podcast called "Bring Back Bronco" that you all should check out. I think there was just 7 or so episodes and they dedicated an episode to each Bronco "era". They did one on the OJ impact on the Bronco legacy and it was extremely interesting.JP Chestnut wrote: ↑Fri Apr 16, 2021 11:03 amThere's only one white Ford Bronco worth that much money:BlueSky wrote: ↑Thu Apr 01, 2021 9:23 amA mere 59K...
Someone around the corner has a white Bronco Sport. I wasn't expecting it to look so small, but I guess it is a micro Ute.
Users browsing this forum: Google [Bot] and 287 guests
