Discussion of Sinn watches.
- Admin
Post
by CGSshorty » Fri Nov 06, 2020 4:44 pm
BacoNoir wrote:Is the 105 GMT a jump hour hand or jump GMT hand movement?
Direct from Rob at WatchBuys:
“It works the same way as the Sinn 856 UTC. The hand constantly moves to show the time between hours, but if you activate the crown to move it backwards or forwards in time it jumps in one hour increments”.
- Name: Pedro
Post
by gr8sw » Fri Nov 06, 2020 5:19 pm
I like this one the most of these...
isn't the stacked day-date not a UTC, only the ones with date like this
- Name: Eric
Post
by HapaHapa » Fri Nov 06, 2020 5:28 pm
Not keen on green.
I don’t see any of these models as improvements. If I had the money I’d spend it on one of the “older designs”, maybe 104 with white dial.
- Name: Eric
Post
by HapaHapa » Fri Nov 06, 2020 5:32 pm
CGSshorty wrote: ↑Fri Nov 06, 2020 4:44 pm
Bali H’ai C works same way. Very nice trick.
streetracer101
Post
by streetracer101 » Fri Nov 06, 2020 6:05 pm
I dig that green U1. Too bad you have to live in Germany to purchase one.
Bradley_Goodchil
Post
by Bradley_Goodchil » Fri Nov 06, 2020 6:24 pm
Printed dial is a no deal for me... Applied indices are a must.... Otherwise I feels like they are just cutting corners
Sent from my HMA-L09 using Tapatalk
- Admin
Post
by CGSshorty » Fri Nov 06, 2020 7:02 pm
Bradley_Goodchil wrote:Printed dial is a no deal for me... Applied indices are a must.... Otherwise I feels like they are just cutting corners
Is IWC “cutting corners” here?
- Name: Eric
Post
by HapaHapa » Fri Nov 06, 2020 10:16 pm
CGSshorty wrote: ↑Fri Nov 06, 2020 7:02 pm
If you compare the hands to the U1, then yes they cut the corners off the LEGO hands
- Admin
Post
by CGSshorty » Fri Nov 06, 2020 11:03 pm
HapaHapa wrote:CGSshorty wrote: ↑Fri Nov 06, 2020 7:02 pm
I haven’t made up my mind about the hands yet. I need to see it on my wrist. Generally, I prefer hands with a pointer that hits right on the minute markers.
- Name: Chris
Post
by Ryeguy » Sat Nov 07, 2020 4:24 am
This is the same as an ETA 2893-2 I believe, so a jump hour GMT hand.
I’m guessing the 7750 modifications are done by Sinn themselves using their own watchmakers.
- Name: Chris
Post
by Ryeguy » Sat Nov 07, 2020 4:43 am
gr8sw wrote: ↑Fri Nov 06, 2020 5:19 pm
Correct. Different movements in the watches with stacked day date displays.
What I find interesting is the Sellita 220-1 and 330-1 (day / date versus date / UTC) are slightly different diameters and thicknesses.
At a minimum this means they use uniquely sized movement rings. If the stem height is different, they might even have differently machined cases.
- Name: Roger
Post
by BacoNoir » Sat Nov 07, 2020 8:04 am
Ryeguy wrote:CGSshorty wrote: ↑Fri Nov 06, 2020 4:44 pm
Ok, thanks. The “it” moves backwards or forwards was throwing me off. I guess to see local time on the watch, you could use the crown to set the hour hand to local time and then use the jump hour function to reset the GMT hand to your home timezone or whatever you had it set to.
Bradley_Goodchil
Post
by Bradley_Goodchil » Sat Nov 07, 2020 9:14 pm
CGSshorty wrote:Bradley_Goodchil wrote:Printed dial is a no deal for me... Applied indices are a must.... Otherwise I feels like they are just cutting corners
By cutting corners I mean saving costs, printed dials look cheap to me, that photo you posted is pretty ugly
To each his own
Axelay2003
- Name: Gerard
Post
by Axelay2003 » Mon Nov 09, 2020 4:31 am
The green dial U1 is polarizing. Nothing captures me with the new offering.
Post
by Captdave » Mon Nov 09, 2020 5:16 am
jimyritz wrote:Those 105’s are meh....
Users browsing this forum: No registered users and 203 guests
