djh1201
- Name: David H.
Post
by djh1201 » Fri May 29, 2020 12:27 pm
Pardon my ignorance, but I've been struggling to find some info on bezel diameters for the various iterations of the Planet Ocean. Maybe I'm wrong, but the bezel appears slightly smaller than the case on most (if not all) of the Planet Oceans.
Personally would love to see everyone start quoting Bezel diameters, L2L, and even Dial diameter since in my experience these are the most important measurements as to how a watch looks on my wrist. Who the hell cares about case diameter anyways??
- Name: Greg
Post
by gwells » Fri May 29, 2020 2:31 pm
my digital calipers on my 8500 say 40.6mm for the bezel.
djh1201
- Name: David H.
Post
by djh1201 » Fri May 29, 2020 2:50 pm
gwells wrote: ↑Fri May 29, 2020 2:31 pm
Awesome - thanks! So if I'm looking for a bezel diameter around 42mm looks like I need to look at the larger models. All the 43.5 models are pretty tall watches, aren't they?
- HJ
- Name: Hoppy
Post
by hoppyjr » Fri May 29, 2020 3:25 pm
djh1201 wrote:gwells wrote: ↑Fri May 29, 2020 2:31 pm
The original 45.5 mm 2500 series PO wears large and relatively flat for its size. I always thought the bezel diameter made it feel about 43.5 on my wrist.
The 45.5 mm 8500 is definitely on the thicker side, about 17mm as I recall. Think Deepsea Seadweller.
The newest 43.5 mm 8900 series PO is thinner than the 8500 series, but still a little chunky. With its bezel it wears about like a 42mm piece to me. For my money it’s the best yet.
- Masshole
Post
by jimyritz » Fri May 29, 2020 3:27 pm
They might be tall but L2L is reasonable even for a smaller 6.75-7" wrist...
SoCal C4S
- Name: RJ
Post
by SoCal C4S » Fri May 29, 2020 3:55 pm
The 45.5mm PO 2500 series is the most wearable large watch (44mm or larger) that I have ever owned. And I’ve owned pretty much everything larger than 40mm under $20k.
djh1201
- Name: David H.
Post
by djh1201 » Fri May 29, 2020 4:01 pm
wow, thanks guys, now I'm wondering if I can comfortably pull off the 45.5 on my 7.25 wrist...
SoCal C4S
- Name: RJ
Post
by SoCal C4S » Fri May 29, 2020 4:11 pm
djh1201 wrote:wow, thanks guys, now I'm wondering if I can comfortably pull off the 45.5 on my 7.25 wrist...
You definitely can. Many people with wrists smaller than yours have and still do wear that, and much larger, thicker watches.
- Wu
- Name: m@
Post
by matt.wu » Fri May 29, 2020 5:11 pm
I have two 42mm 8500 POs I’ve been procrastinating on listing....
djh1201
- Name: David H.
Post
by djh1201 » Fri May 29, 2020 5:37 pm
matt.wu wrote: ↑Fri May 29, 2020 5:11 pm
Thanks, but I think it's going to be a little small for my taste based on the above discussion. Probably need to save up for the 43.5.
- Name: Greg
Post
by gwells » Fri May 29, 2020 6:43 pm
it really comes down to what you like.
personally my 42mm 8500 is as big as i'd go on my 7.25 wrist. the only exceptions i've found are the U1, which still feels a little heavy but it wears smaller than it's case size because of the lugs, and the seiko turtle.
Post
by logan2z » Fri May 29, 2020 7:00 pm
SoCal C4S wrote: ↑Fri May 29, 2020 3:55 pm
Agreed, mine wears very well on my 7" wrist.
blkgsl
- Herro!!!
- Name: blkgsl
Post
by blkgsl » Fri May 29, 2020 7:05 pm
Nope, not with the 8500 movement thickness imo. I find the 42 8500 most comfortable, and I’m around 7-7.25 right now.
SoCal C4S
- Name: RJ
Post
by SoCal C4S » Fri May 29, 2020 7:09 pm
The 2500 wears much differently than the 8500. Less thick/tall, and obviously less top heavy.
In a similar way, the SD43 wears much better than the DeepSea does. Nearly the same watch, but one is much thicker and heavier than the other.
- HJ
- Name: Hoppy
Post
by hoppyjr » Fri May 29, 2020 9:03 pm
I agree, the 42mm PO 8500 reminds me of a bit larger Sea Dweller.
The 43.5 PO 8900 has different end links and wears about the same as the 42/8500 height wise, but it’s got a bit larger footprint.
FWIW- the 42mm 8500 has 20mm lugs, the 45.5 PO’s all have 22mm lugs, and the 43.5 has oddball 21mm lugs. If you plan to swap straps and such that may matter. If wearing solely on bracelet, my pick remains the 43.5. In blue.
ChuckW
- Name: Chuck
Post
by ChuckW » Thu Jun 04, 2020 6:55 am
Just for reference, this is what a 42mm 2500D looks like on a 7.75" wrist. I've owned a PO xl 2500D and an 8500 xl and prefer the smaller model.
Sent from my Moto Z3 Play using Tapatalk
ChuckW on Thu Jun 04, 2020 1:29 pm, edited 1 time in total.
No, it's not Tourettes.
Post
by Captdave » Thu Jun 04, 2020 9:11 am
I wear the 45.5 2500 regularly on my 7.5 wrist with no problem. Have for over 10 years. Should work for you.
ChuckW
- Name: Chuck
Post
by ChuckW » Thu Jun 04, 2020 1:28 pm
ChuckW wrote: ↑Thu Jun 04, 2020 6:55 am
djh1201
- Name: David H.
Post
by djh1201 » Thu Jun 04, 2020 2:40 pm
Hmm, guess it was a valid question, as the answer isn't obvious. Maybe it is time to find an Omega boutique, to hell with the Pandemic!
Erratic101
- Name: Justyn
Post
by Erratic101 » Thu Jun 04, 2020 2:46 pm
How tall is the 42mm 8500? And how tall is the 2500?
ChuckW
- Name: Chuck
Post
by ChuckW » Thu Jun 04, 2020 3:13 pm
Erratic101 wrote: ↑Thu Jun 04, 2020 2:46 pm
I've seen different specs for the 42mm/2500 that have the thickness anywhere from 14mm to 15.5. I don't have calipers, but using a ruler, it looks less than 14mm.
- Name: Greg
Post
by gwells » Thu Jun 04, 2020 3:36 pm
8500 (by my calipers) is 16mm (since i'm wearing it and calipers are right here on my desk).
Erratic101
- Name: Justyn
Post
by Erratic101 » Thu Jun 04, 2020 4:18 pm
gwells wrote:8500 (by my calipers) is 16mm (since i'm wearing it and calipers are right here on my desk).
Damn, that is thick for a 3 hander!
SoCal C4S
- Name: RJ
Post
by SoCal C4S » Thu Jun 04, 2020 5:10 pm
The 8500 is significantly thicker (think Rolex DeepSea), and the 2500 is about as think as a standard Seiko diver.
- Name: Greg
Post
by gwells » Thu Jun 04, 2020 6:59 pm
honestly, it doesn't feel that bad when i compare it to other 42ish mm divers.
Users browsing this forum: No registered users and 14 guests
