Discussion of Ægir watches.
Moderator: t20569cald
Post
by jeckyll » Fri Oct 23, 2015 10:49 am
A few times now I've had the bars come loose and luckily noticed each time. Anyone use blue locktite to ensure thing stay in place?
Thanks
- Admin
Post
by CGSshorty » Fri Oct 23, 2015 11:32 am
I wouldn't. If you must, use purple.
- Capt. Obvious
- Name: Wayne
Post
by marchone » Fri Oct 23, 2015 11:35 am
On a springbar? Just trying to understand.
marchone on Fri Oct 23, 2015 11:36 am, edited 1 time in total.
- Admin
Post
by CGSshorty » Fri Oct 23, 2015 11:35 am
marchone wrote:On a springbar?
They are screw bars, like a Panerai.
- Capt. Obvious
- Name: Wayne
Post
by marchone » Fri Oct 23, 2015 11:36 am
Got it. Is purple weaker than blue?
- Admin
Post
by CGSshorty » Fri Oct 23, 2015 11:41 am
marchone wrote:Got it. Is purple weaker than blue?
Yes. It is made for very small screws that sometimes need to be adjusted, like in a carburetor.
james80
- Name: James
Post
by james80 » Fri Oct 23, 2015 11:42 am
Is this common with other owners? If not and it's only yours maybe they are worn and a new set is in order?
- HJ
- Name: Hoppy
Post
by hoppyjr » Fri Oct 23, 2015 11:54 am
Try using tubes the the straps. The common cause of screws coming loose is the strap catching on the bar and applying friction. The strap tube will provide a smoother metal-to-metal contact which should eliminate or reduce the problem.
- Bean Counter Extraordinaire
- Name: William Drayton, Jr.
Post
by andrema » Fri Oct 23, 2015 12:10 pm
mine never come loose...
Post
by jeckyll » Fri Oct 23, 2015 12:13 pm
Thanks for all the tips:
1) Will get some purple, that makes sense and this is why I asked.
2) Ed: they come lose on the straps that are already thick and therefore pinch between the case and the bar, so when the strap is moved it turns the bar. I may try to get a needle file and thin out a few of my 24mm straps, maybe that would help.
- TRTV!
- Name: Tommy Tutone
Post
by T.R. » Fri Oct 23, 2015 12:19 pm
Doxa used to ship their watches with the light Locktite product to be used with their screw pins for links, if that is of help. You could also use white Teflon plumbing tape to lock them in lightly.
Post
by jeckyll » Fri Oct 23, 2015 12:31 pm
T.R. wrote:Doxa used to ship their watches with the light Locktite product to be used with their screw pins for links, if that is of help. You could also use white Teflon plumbing tape to lock them in lightly.
Yeah, I debated teflon tape. Thanks!
t20569cald
Post
by t20569cald » Fri Oct 23, 2015 3:52 pm
To stop it happening on rubber, ream out the hole slightly with a diamond dremel tool or some such thing. It is only a small amount that needs to come out to stop it.
The bars are a touch thicker than most.
- The Grumpy Global Mod
- Name: Mr. Dibs
Post
by BSears » Fri Oct 23, 2015 4:02 pm
andrema wrote:mine never come loose...
Same here.
Post
by toxicavenger » Fri Oct 23, 2015 4:11 pm
BSears wrote:andrema wrote:mine never come loose...
Same here.
ditto
- Name: Mr. Dibs
Post
by BSears » Fri Oct 23, 2015 4:12 pm
+3
- Name: Mr. Dibs
Post
Oh wait. Sorry. Just boosting my post count.
james80
- Name: James
Post
by james80 » Fri Oct 23, 2015 4:14 pm
BSears wrote:Oh wait. Sorry. Just boosting my post count.
0.003% increase. Well done
- Name: Mr. Dibs
Post
by BSears » Fri Oct 23, 2015 4:27 pm
Every little bit counts. Ask Deez
- Name: Mr. Dibs
Post
by BSears » Fri Oct 23, 2015 4:28 pm
That's quick math too. You might just exceed the IQ level for Dee dub.
james80
- Name: James
Post
by james80 » Fri Oct 23, 2015 4:31 pm
Dee dub??
- Admin
Post
by CGSshorty » Fri Oct 23, 2015 4:32 pm
james80 wrote:Dee dub??
Dee Dub You See
Axelay2003
- Name: Gerard
Post
by Axelay2003 » Fri Oct 23, 2015 5:08 pm
A
james80
- Name: James
Post
by james80 » Fri Oct 23, 2015 6:56 pm
CGSshorty wrote:james80 wrote:Dee dub??
Dee Dub You See
Nope, I've got nothing.
- Name: Eric
Post
by HapaHapa » Fri Oct 23, 2015 7:21 pm
I
Hate
Loctite
Users browsing this forum: No registered users and 12 guests
