AEgir Tubes?
Moderator: t20569cald
- manitoujoe
- Name: Mark
AEgir Tubes?
Has anyone bought tubes for straps that live on their CD-2s? I’ve got a olive canvas that I cannot line the screw bar correctly on. I figured if there was nowhere to go, I’d have an easier time.
I ordered some from Panatime but they were too narrow. The bars are 2mm. Hoping someone has a good source. Thanks in advance!
Steve Martin
Steve Martin
Re: AEgir Tubes?
I didn’t on the Aegir, but I had a similar problem with a different watch (and I don’t remember which one lol!). The solution was H2O tubes.
- manitoujoe
- Name: Mark
Re: AEgir Tubes?
You are awesome. Thank you! Hopefully they sell them separately.
Steve Martin
Steve Martin
- tattoo chef
- <Will Skull for Food>
- Name: Don
Re: AEgir Tubes?
I am being dense for sure, but what are we talking about lining up?toxicavenger wrote:I used a paper clip to line it up
Re: AEgir Tubes?
The tube holes in the case to the screw bars. That way you can screw the ends in easier. I think Kobold use to make a tool for this if I recall.tattoo chef wrote: ↑Thu May 03, 2018 7:11 pmI am being dense for sure, but what are we talking about lining up?toxicavenger wrote:I used a paper clip to line it up
- tattoo chef
- Name: Don
Re: AEgir Tubes?
I’ve never run into this issue, ever.toxicavenger wrote:The tube holes in the case to the screw bars. That way you can screw the ends in easier. I think Kobold use to make a tool for this if I recall.tattoo chef wrote: ↑Thu May 03, 2018 7:11 pmI am being dense for sure, but what are we talking about lining up?toxicavenger wrote:I used a paper clip to line it up
Re: AEgir Tubes?
Sometimes on a thicker strap you can't push the screw bar all the way through it and have it line up to the hole on the case. I personally have moved the strap around to line it up or just use the end of a paper clip.tattoo chef wrote: ↑Thu May 03, 2018 7:21 pmI’ve never run into this issue, ever.toxicavenger wrote:The tube holes in the case to the screw bars. That way you can screw the ends in easier. I think Kobold use to make a tool for this if I recall.tattoo chef wrote: ↑Thu May 03, 2018 7:11 pmI am being dense for sure, but what are we talking about lining up?toxicavenger wrote:I used a paper clip to line it up
Re: AEgir Tubes?
Me neithertattoo chef wrote:I’ve never run into this issue, ever.toxicavenger wrote:The tube holes in the case to the screw bars. That way you can screw the ends in easier. I think Kobold use to make a tool for this if I recall.tattoo chef wrote: ↑Thu May 03, 2018 7:11 pmI am being dense for sure, but what are we talking about lining up?toxicavenger wrote:I used a paper clip to line it up
Re: AEgir Tubes?
So the screw bars just automatically went into the lug holes on the other side?Jeep99dad wrote: ↑Thu May 03, 2018 8:07 pmMe neithertattoo chef wrote:I’ve never run into this issue, ever.toxicavenger wrote:The tube holes in the case to the screw bars. That way you can screw the ends in easier. I think Kobold use to make a tool for this if I recall.tattoo chef wrote: ↑Thu May 03, 2018 7:11 pmI am being dense for sure, but what are we talking about lining up?toxicavenger wrote:I used a paper clip to line it up
Sent from my iPhone using Tapatalk![]()
Re: AEgir Tubes?
Pretty much or with just a little guidance. I mean nothing crazy.toxicavenger wrote:So the screw bars just automatically went into the lug holes on the other side?Jeep99dad wrote: ↑Thu May 03, 2018 8:07 pmMe neithertattoo chef wrote:I’ve never run into this issue, ever.toxicavenger wrote:The tube holes in the case to the screw bars. That way you can screw the ends in easier. I think Kobold use to make a tool for this if I recall.tattoo chef wrote: ↑Thu May 03, 2018 7:11 pmI am being dense for sure, but what are we talking about lining up?toxicavenger wrote:I used a paper clip to line it up
Re: AEgir Tubes?
Yep same here. I used a paper clip for the guidance. Or I pushed the strap around to guide it.Jeep99dad wrote: ↑Thu May 03, 2018 9:17 pmPretty much or with just a little guidance. I mean nothing crazy.toxicavenger wrote:So the screw bars just automatically went into the lug holes on the other side?Jeep99dad wrote: ↑Thu May 03, 2018 8:07 pmMe neithertattoo chef wrote:I’ve never run into this issue, ever.toxicavenger wrote:The tube holes in the case to the screw bars. That way you can screw the ends in easier. I think Kobold use to make a tool for this if I recall.tattoo chef wrote: ↑Thu May 03, 2018 7:11 pmI am being dense for sure, but what are we talking about lining up?toxicavenger wrote:I used a paper clip to line it up
Re: AEgir Tubes?
FWIW, I think having tubes in softer material straps is just a good idea from a general practice perspective. I've noticed Seiko has started adding tubes to their new generation rubber straps (the ones that feel softer, almost silicone-like, such as the model included with the SLA017 and SBDC053).
Obviously, only use tubes on watches with drilled lugs.
- manitoujoe
- Name: Mark
Re: AEgir Tubes?
It’s only been an issue on this one canvas strap. I spent an hour patiently trying to guide the screwbar into the hole. I have no idea if it’s a thickness thing or what.
Just trying to find an easy solution. I’ll try the paper clip idea.
Steve Martin
Steve Martin
- Axelay2003
- Name: Gerard
Re: AEgir Tubes?
Too thick.manitoujoe wrote: ↑Fri May 04, 2018 4:47 amIt’s only been an issue on this one canvas strap. I spent an hour patiently trying to guide the screwbar into the hole. I have no idea if it’s a thickness thing or what.
Re: AEgir Tubes?
2 screwdrivers....its always the answer....call Wjean
- manitoujoe
- Name: Mark
Re: AEgir Tubes?
It’s a single-end threaded screwbar so only 1 screwdriver needed. No luck guiding the bar.
I’m at a loss. There has to be a way.
Steve Martin
Steve Martin
- tattoo chef
- Name: Don
Re: AEgir Tubes?
I honestly have never encountered this issue. Is the strap hitting the inside of the lugs so much that it’s just too thick and not enough clearance? I mean, the Ægir comes on an isofrane, so how thick is this strap?manitoujoe wrote:It’s a single-end threaded screwbar so only 1 screwdriver needed. No luck guiding the bar.
Re: AEgir Tubes?
If the strap is that thick a tube won’t help.
- manitoujoe
- Name: Mark
Re: AEgir Tubes?
I can’t imagine it’s too thick. It’s a normal canvas strap. Not sure who made it. I think something on the inside of the strap is nudging it just out of sync with the hole.
When I try other straps, it kind of sinks into the threaded hole and all is good. With this one, it just never does.
I’m getting so frustrated I’m probably going to sell the strap. Not the AEgir’s fault. Lol
Steve Martin
Steve Martin
Re: AEgir Tubes?
The CD-2 is a pain in the ass for straps. I never take mine off the Isofrane.
Re: AEgir Tubes?
Gonna necrobump this because I think I'm fighting the same problem on the same watch (I think I bought the watch in question).
Re: AEgir Tubes?
The canvas strap wasn't going to work any more than the tapered benarofrane I'd like on the CD-2. Isofrane it is, and based on how well it fits I would bet that the lug holes were spaced based on Isofrane dimensions. The iso is the center strap in the "ends" photo.
Re: AEgir Tubes?
Todd me he had to bore out the stock Isofranes to work.
Re: AEgir Tubes?
That smells like a mistake was made. I'll compare my Aegir Iso to a 22mm tonight.toxicavenger wrote: ↑Mon May 13, 2024 8:53 pmTodd me he had to bore out the stock Isofranes to work.
Users browsing this forum: No registered users and 31 guests
