Houston, I needs some help!
Discussion of straps and bracelets.
AZpops
Post by AZpops » Fri Nov 05, 2021 9:46 am
Although I've been wearing the Ninja Tuna for the past year, or so. I still can't get use to Seiko's rubber strap (it seems to get clammy, so I take it off from time to time to air my wrist).
Purchased a 22mm Strapcode DLC Super Engineer I bracelet. Tried installing the bracelet this morning, and the straight end goes in just shy of the half way point (where the pin will hit the lug hole). I think between Seiko's black coating, and the DLC coating on the bracelet is preventing it to go any further. I purchased the DLC in lieu of the PVD for it's durability (?).
https://www.strapcode.com/collections/m ... 3264128084
Any ideas how I can get the ends to reach the 1/2 way point? I could use a grinder, but would like to avoid doing that, as well as using a hammer and chisel. ... :grin:
Thanks!
Lance
Re: Houston, I needs some help!
Post by HapaHapa » Fri Nov 05, 2021 7:57 pm
I’d sandpaper the coating off the edges of the bracelet end links as a starter. It’s going to scrap off eventually anyhow.
AZpops
Post by AZpops » Sat Nov 06, 2021 5:06 am
Thanks, gonna pick up some fine grade wet sand paper. Then see how it goes.
Lance
AZpops
Post by AZpops » Sat Nov 06, 2021 11:42 am
Bought the sandpaper (assorted wet/dry grades). The other thing I was thinking about, was to freeze the bracelet for a few days. Then do a press fit sort of thing. But then I figured if it worked, the fit would be so tight, once the bracelet expanded/warmed up it wouldn't swivel. ... :lol:
Anyways, as soon as I order my friend's gift. I'll see how it goes!
Thanks again!
It would be so easy if Seiko would make a coated bracelet for the dang watch!
Lance
AZpops
Post by AZpops » Wed Dec 01, 2021 8:38 am
Worked! Used the 850 grit paper.
Lance
hobbit712
Post by hobbit712 » Wed Dec 01, 2021 8:56 am
Nice! That looks great.
instagram @watchidiotsavants
AZpops
Post by AZpops » Wed Dec 01, 2021 9:38 am
Thanks! Kind of heavy, but after a couple of days. I don't notice the weight. Lots more comfortable then the rubber strap.
Lance
Post by HapaHapa » Thu Dec 02, 2021 6:55 pm
Yes yes! Very noice!!
AZpops
Post by AZpops » Fri Dec 03, 2021 9:16 am
:thumbsup: ... :cheers:
Lance
Users browsing this forum: No registered users and 200 guests
