Possibly...maybe...trial run?
Incoming: moto 360 2nd gen smartwatch.
Yep. Should be here Wednesday. Not sure it will last, or even stay, but its going to get a try.
This is the build...46mm with 22mm horween strap.
I'm a Heretic
I'm a Heretic
Beaver? It's a damn badger - it even says so on the poster....
Gordo.
Gordo.
Re: I'm a Heretic
Nice. It's pretty cool. I use mine a few times a week. Great when driving and having navigation going to your wrist versus holding your phone to watch turn by turn..the straps is shit btw. Took it off and swapped it first thing for a drew strap I have.
Re: I'm a Heretic
Oh and thousands of dials you can download which is fun.
Re: I'm a Heretic
fuckin cool.ericf4 wrote:Oh and thousands of dials you can download which is fun.
..any other steam punk styles? I could see how it might be addicting.
Re: I'm a Heretic
An overwhelming amount of them...
Re: I'm a Heretic
I've read the strap is crap so if I keep it I'm expecting to swap it out.
I've already found some dials I'd like to try and Eric is right there are thousands of them.
I'm a project manager of both field projects and engineering projects plus I operate construction equipment some days... If I'm operating a machine I have to check my phone (usually in my pocket) numerous times to check on who's calling/emailing/texting etc.. Do that about 20 times an hour and you've been unproductive not to mention worn your arm and hand out...
I'm not in it for the techgeek factor...and realize it probably won't have a lengthy life in this environment.
As to wayne's comment, I wear almost all 44-46mm watches... My wrist is over 8.3" and I'm 6'4" so that's not a an issue.. There is however a 42mm option with 20mm strap.
Gordo.
Gordo.
Re: I'm a Heretic
This larger option wears well even on my small wrist. Check out the Google + page for watchmaker- beautiful watches for android... You'll find devs cranking out the best dials around for free. Also check out watchawear for more.
You'll need to download the watchmaker app to your phone from Android store. This is key to access all the best dials out there.
And trust me that Google plus page will take you down a rabbit hole. Unbelievable when you dig around there.
