Starting to Not Liking Windows 10
- 59yukon01
- 1.21 gigawatts?!
Re: Starting to Not Liking Windows 10
Yes Windows 10 sucks! However, it can be set-up to look/feel like Windows 7. My IT guy did so for me.
- AZpops
- Name: Lance
I wish I had a go to guy like your friend! I'm just glad my windows 7 laptop is still going!
Lance
- 59yukon01
- 1.21 gigawatts?!
To be fair it's my work laptop and my company's internal IT took care of it.
- AZpops
- Name: Lance
OK, either way, the main thing things are doing better. I kind of wish I left the windows 7 on the Toshiba. Google wasn't updating (kept getting an error), so I tried to uninstall it, but nope won't uninstall. OK, left it alone, then tried installing FireFox. Went through the download thru Mozilla, but when the install green progress bar was at the end. I got a "for some reason couldn't install". checked my desk top, and there's ForeFox (but in a muted color). Tried uninstalling FireFox, but the darn thing kept going, and wouldn't uninstall.
Oh well!
Lance
- jeckyll
I don't think those are 'Windows 10' issues. While I appreciate that you're having problems post upgrade, it sounds like there is something else wrong, or your upgrade was not fully successful.
If anything, it sounds like the account you're using isn't an administrator account, or some permissions got messed up. Unfortunately, based on what I've read, I'm not sure what to suggest to you to fix it.
I recently did a win7 -> win10 upgrade and was surprised how relatively smoothly it worked. Not a fan of Win10 overall, but much can be tweaked to make it less annoying.
Classic shell was great for getting my windows 7 vibe back.
Microsuck hasn't had a stable OS since Windows for Workgroups
starting to not like it?? It came out like in 2015......
Are you just starting to use it? I think it got way better over time, didnt like it at first,
- Erratic101
- Name: Justyn
Windows ‘98 for life!
- jeckyll
That's simply incorrect.four20 wrote:Microsuck hasn't had a stable OS since Windows for Workgroups
- AZpops
- Name: Lance
When I did the upgrade, I guess it went well. All seemed to go smoothly, but then, what do I know. ...jeckyll wrote: ↑Thu Feb 27, 2020 7:47 amI don't think those are 'Windows 10' issues. While I appreciate that you're having problems post upgrade, it sounds like there is something else wrong, or your upgrade was not fully successful.
Thanks!
Oh, and thanks everybody for the feed back! Appreciated it! ...
Lance
- jeckyll
When you get to it, here are a few things that may help:AZpops wrote: ↑Thu Feb 27, 2020 2:15 pmWhen I did the upgrade, I guess it went well. All seemed to go smoothly, but then, what do I know. ...jeckyll wrote: ↑Thu Feb 27, 2020 7:47 amI don't think those are 'Windows 10' issues. While I appreciate that you're having problems post upgrade, it sounds like there is something else wrong, or your upgrade was not fully successful.
I recently did a win7 -> win10 upgrade and was surprised how relatively smoothly it worked. Not a fan of Win10 overall, but much can be tweaked to make it less annoying.... I'm doing the 12 to 14 hour shifts from tonight, so I'll play with it next week. The main thing I guess, is Microsoft Works and my printer is working. I started using Edge last night and that seems to be working OK.
Thanks!
Oh, and thanks everybody for the feed back! Appreciated it! ...![]()
1. check the event log for errors and google them (the system log).
2. go to users and check if the account that you're using is an administrator account. If not, then something is seriously messed up.
3. if so, maybe set up a new user on the system, log in as that user and then see if you have the same issues (sounds like something got corrupted during the migration).
4. if none of those work, download Malewarebytes and see if you can do a full system scan to see if you got something nasty on the computer. If you can't install that either, it's possible you need to re-install Windows / try to do something more low-level to restore the OS to a functional state.
Hope that helps and one of those will get you up and running.
Bjorn
- AZpops
- Name: Lance
Thanks! First program I installed was Malwarebytes Premium, and CCleaner Pro! Have both on my Windows 7 laptop as well! ...jeckyll wrote: ↑Fri Feb 28, 2020 7:58 amWhen you get to it, here are a few things that may help:AZpops wrote: ↑Thu Feb 27, 2020 2:15 pmWhen I did the upgrade, I guess it went well. All seemed to go smoothly, but then, what do I know. ...jeckyll wrote: ↑Thu Feb 27, 2020 7:47 amI don't think those are 'Windows 10' issues. While I appreciate that you're having problems post upgrade, it sounds like there is something else wrong, or your upgrade was not fully successful.
Thanks!
Bjorn
This is the reason I was trying to update Chrome on the Toshiba (Chrome in my windows 7, updated without a hitch);
I also did a YouTube search on the uninstall, and it seems to be a problem.
OK, going to crash and get some Z's! ....
Lance
- AZpops
- Name: Lance
I checked User Accounts, and I am Local Account / Administrator. I checked the event log, but there isn't anything listed. As noted earlier, I purchased Malwarebytes Premium, did the scan, and nah dah, all's good.jeckyll wrote: ↑Fri Feb 28, 2020 7:58 amWhen you get to it, here are a few things that may help:AZpops wrote: ↑Thu Feb 27, 2020 2:15 pmWhen I did the upgrade, I guess it went well. All seemed to go smoothly, but then, what do I know. ...jeckyll wrote: ↑Thu Feb 27, 2020 7:47 amI don't think those are 'Windows 10' issues. While I appreciate that you're having problems post upgrade, it sounds like there is something else wrong, or your upgrade was not fully successful.
Thanks!
Bjorn
Thanks!
Lance
- jeckyll
Too bad none of those things addressed your issue!
- AZpops
- Name: Lance
Still trying to recover, but I'll start watching a few youtube vids I found, re. uninstalling Chrome. See how it goes. Thanks!
Lance
- bedlam
- Name: Carl
Pretty annoying. I've been lucky with Win10 so far, its been solid.
Personally I'd dump Chrome...its essentially spyware.
https://hothardware.com/news/study-clai ... un-firefox
https://www.washingtonpost.com/video/bu ... video.html
- jeckyll
Agree on not using chrome.bedlam wrote:Pretty annoying. I've been lucky with Win10 so far, its been solid.
- AZpops
- Name: Lance
Thanks for the tip. Problem is, I tried installing FireFox, and guess what? It wouldn't install! ...jeckyll wrote: ↑Thu Mar 05, 2020 7:33 amAgree on not using chrome.bedlam wrote:Pretty annoying. I've been lucky with Win10 so far, its been solid.
Thanks again!
Lance
- jeckyll
Yeah, you have a problem that's not related to the browser.AZpops wrote: ↑Thu Mar 05, 2020 11:20 amThanks for the tip. Problem is, I tried installing FireFox, and guess what? It wouldn't install! ...jeckyll wrote: ↑Thu Mar 05, 2020 7:33 amAgree on not using chrome.bedlam wrote:Pretty annoying. I've been lucky with Win10 so far, its been solid.
https://www.washingtonpost.com/video/bu ... video.html... I guess I'll try again!
Thanks again!
- AZpops
- Name: Lance
I wish I knew more about this sort of stuff. Malwarebytes had a update, which I did a few minutes ago on this windows 7 laptop, and all as expected went well. I'll fire up the Toshiba later, as I'm sure the update will be on that computer as well. Give it a shot an see how it goes.jeckyll wrote: ↑Thu Mar 05, 2020 7:53 pmYeah, you have a problem that's not related to the browser.AZpops wrote: ↑Thu Mar 05, 2020 11:20 amThanks for the tip. Problem is, I tried installing FireFox, and guess what? It wouldn't install! ...jeckyll wrote: ↑Thu Mar 05, 2020 7:33 amAgree on not using chrome.bedlam wrote:Pretty annoying. I've been lucky with Win10 so far, its been solid.
Thanks again!
Lance
are you sure you are an admin on your pc? https://www.technipages.com/windows-ins ... -computers
- AZpops
- Name: Lance
toxicavenger wrote: ↑Sat Mar 07, 2020 7:47 pmare you sure you are an admin on your pc? https://www.technipages.com/windows-ins ... -computers
Sorry for the delayed thanks, T. I'll check into the link / instructions tomorrow. Been preoccupied with stuff, know how that goes.
Thanks again!
Lance
- jeckyll
That's what I askedtoxicavenger wrote: ↑Sat Mar 07, 2020 7:47 pmare you sure you are an admin on your pc? https://www.technipages.com/windows-ins ... -computers
Users browsing this forum: No registered users and 32 guests
