New design, thoughts and opinions...
Discussion of SAS Watches and Míleata Military Watches
Moderator: Graeme
Axelay2003
Re: New design, thoughts and opinions...
Post by Axelay2003 » Wed Jan 27, 2016 4:46 pm
Graeme wrote:I think the best fix for the lugs is to loose the taper on the bracelet.
No.
Axelay2003
Post by Axelay2003 » Wed Jan 27, 2016 4:49 pm
Graeme wrote:Regarding the lugs.
I am reluctant to change the lugs for a few reasons.
1, I don't want to stray to far away from the SEA-01 case.
2, To add a taper to match the BOR links, doesn't really work. I have drawn a few samples to show you.
This one shows the taper viewed from the top,.....
This one shows the side, you can see that the screwbars don't sit flush with the side of the lug (my OCD is going into hyperdrive)
And on this one with the rubber strap you can see the lugs don't give the feel of the SAS case.
Yes, but I would still chamfer the outer corners of the lugs.
Disc Golfer 209
Post by Disc Golfer 209 » Wed Jan 27, 2016 10:41 pm
Love it. I wouldn't change a thing.
Looks amazing. This will reach goal on Kickstarter with this sweet spot of 42mm X 49mm within a week or maybe 3-4 days.
I'll be happy to share it everywhere so people benefit from it.
I think you hit an absolute home run here and would love to prove those doubters wrong if you leave it as is.
I've seen some ugly watches reach and surpass Kickstarter goal by many multiples. This looks ridiculously good and it should be put out in a huge platform like KS for more people to enjoy and with Miyota to make it more affordable.
hobbit712
Post by hobbit712 » Thu Jan 28, 2016 3:23 am
Since changing the case is out, what about changing the BOR to match the case width? Essentially widen the end pieces to meet the lugs.
instagram @watchidiotsavants
Post by giosdad » Thu Jan 28, 2016 4:45 am
giosdad wrote: The Irish Made The last few watch companies I followed make their target several times iverw
Barry is sipping the limoncello again.
LOL. These days I am working on the single malt and JW blue Kelly game me for Christmas!
Not sure what happened there but I was typing on the iPad and falling asleep. Work is killing me. Maybe I am the one that crashed Safari for Apple.
james80
Post by james80 » Thu Jan 28, 2016 4:55 am
I like that a lot, wasn't keen on the first set of hands but now it looks better.
I'm also not sure about the solid endlink, I think it makes the case look too blocky, can you expose the ends of the beads in the endlink?
Graeme
Owner - SAS & Míleata
Post by Graeme » Thu Jan 28, 2016 5:04 am
james80 wrote:I like that a lot, wasn't keen on the first set of hands but now it looks better.
I'm also not sure about the solid endlink, I think it make the case look too blocky, can you expose the ends of the beads in the endlink?
Yes I am going to look at the endlink again and play with some ideas. It depends aswell with what the manufacturer can produce.
I will work on it over the next few days.
Post by giosdad » Thu Jan 28, 2016 5:09 am
I like this version and understand the taper, this view of it looks better. If you are going to offer a bracelet this makes sense. As much as I like the vintage look on some watches with a thinner strap the contrast from lug to bracelet look severe without the taper, though it looks OK on the strap.
Post by Joeprez » Thu Jan 28, 2016 5:10 am
I have to echo Shorty and Hoppy... Forget the bracelet, its a perfect strap watch. And use similar hands as the sea-01 or air-01 hands. Also chamfer or smooth the lugs a little.
Post by dnslater » Thu Jan 28, 2016 5:16 am
Definitely keep the bracelet. Non tapering definitely matches the lugs better. I actually liked the original hands. Made it interesting. Either way, excellent watch!
tattoo chef
<Will Skull for Food>
Post by tattoo chef » Thu Jan 28, 2016 5:27 am
CGSshorty wrote:The Mileata doesn't even have spring bars. Who needs a bracelet?
He was talking about the SAS Air
Post by CGSshorty » Thu Jan 28, 2016 5:43 am
I know, Don. I own one. My only point is that not every watch needs a bracelet.
Post by mattcantwin » Thu Jan 28, 2016 5:57 am
This hand set is much better, Grameme, and the watch looks great on the strap! :cheers:
manitoujoe
Post by manitoujoe » Thu Jan 28, 2016 6:25 am
Love it
Steve Martin
carlodwc
Post by carlodwc » Thu Jan 28, 2016 2:32 pm
First of all thank you for sharing your design Graeme, the watch looks great. My favorite version is the one without date window. The hands are better in the traditional design (straight like the below).
The seconds hand could be slightly changed, right now it looks a little funky with that square as the lume dot. Maybe harrowhead shape, like the one for the Halios Delfin as an example. If you want other kind of hands I personally would opt for a shape like the sword hands of the Omega SMP.
Other then that, I agree that the watch should have an option for the bracelet. That is actually one of the reasons I ended up selling the SAS Air watch. However a possible solution could be to make the lug space flat. straight rather then curved, so that any straight ended bracelet could just work and you (Graeme) don't have to sit there and work out the whole thing. This would give one the option to have whatever bracelet he wanted as long as it was straight ended, and more cool looks.
The case could even be modified more toward the cushion case type, like 6309 style to keep the short lugs but add the option of easy bracelet and strap fitting.
This is by far the best design for me.
Post by hoppyjr » Thu Jan 28, 2016 2:39 pm
I'll add;
The "SAS" logo would look better printed in the same white as the lower text. The shiny chrome logo on the Sea-01 was really the only thing I didn't care for on mine. I thought it detracted from the higher end appearance of the dial.
I definitely think the balance of the no-date dial is best, but if one must put a date, I'd ditch the white outlined date window. I think the outline draws the eye to that border and makes the date more difficult to read.
Graeme
Post by Graeme » Thu Jan 28, 2016 3:26 pm
The logo is white paint same as lower text.
Graeme
Post by Graeme » Fri Jan 29, 2016 11:10 am
I have been playing around with the endlinks today, and finally settled on this. I still have to talk with my bracelet guy to make sure they can get it exactly as drawn but this is the idea.
Post by hoppyjr » Fri Jan 29, 2016 11:13 am
Graeme wrote:The logo is white paint same as lower text.
Excellent!
Post by matt.wu » Fri Jan 29, 2016 1:05 pm
Graeme wrote:I have been playing around with the endlinks today, and finally settled on this. I still have to talk with my bracelet guy to make sure they can get it exactly as drawn but this is the idea.
That looks damn good. Rounded lugs look good.
Post by andrema » Fri Jan 29, 2016 1:36 pm
WAY BETTER!!!!!!
manitoujoe
Post by manitoujoe » Fri Jan 29, 2016 2:00 pm
Yes!!!!
Steve Martin
Post by hoppyjr » Fri Jan 29, 2016 2:01 pm
Let get that sucker built and ready for July release :)
Post by CGSshorty » Fri Jan 29, 2016 2:04 pm
That looks great.
Sidheguitarist
Man of many calibers.
Post by Sidheguitarist » Fri Jan 29, 2016 2:14 pm
To echo what others just said; that version looks worked out and squared away. Very nice.
Locked
Users browsing this forum: No registered users and 19 guests
