Yours, the MM200 and white/silver willard glacier dials are really nice. The 62mas and MM200 wear really well for smaller wrists. I'm starting to think the MM200 could be a better daily wear watch than my MM300 as it's quite big and bulky on the bracelet.
New Seiko Thread
- Name: James
Re: New Seiko Thread
I agree. While I really like my MM300, the 62MAS reissues are just really easy daily wear watches.
I also own an SLA017 (the 8L powered LE 62MAS reissue) which wears equally well, but is a bit too nice to beat up on as a daily driver.
The SBDC165 splits the difference nicely.
As an aside, I added a MM300 clasp to my SBDC165 for on-the-fly adjust-ability. I'm not a fan of those fixed-length diver extensions Seiko incorporates on many of their divers. The MM300 clasp is much more useful. I even prefer it over those Strapcode ratchet clasps as the Seiko clasp at least looks normal length when closed. Those Strapcode clasps take up the entire underside of my wrist.
- Name: James
Interesting as I was going to look into replacing the MM300 ratchet clasp with one from the MM200 bracelet as I heard it's a direct fit. I find the ratchet clasp a bit too thick, but perhaps I should give it another shot. I find the bracelet on the MM300 to be a challenge in general as it's heavy and I can't seem to get a good fit by adding/removing a link or adjusting the micro adjustment. I can get a good fit if I release the ratchet once notch, but I don't love the way it looks. I think a rubber strap is my best bet on that watch but I just really like the way it looks on the bracelet.Ryeguy wrote: ↑Tue Feb 07, 2023 8:11 amI agree. While I really like my MM300, the 62MAS reissues are just really easy daily wear watches.
Yes, I agree that walking around with a clasp partially extended as an every day type thing would look kind of odd. For occasional use, fine, but not daily.Mr_Pacman wrote: ↑Tue Feb 07, 2023 8:15 amInteresting as I was going to look into replacing the MM300 ratchet clasp with one from the MM200 bracelet as I heard it's a direct fit. I find the ratchet clasp a bit too thick, but perhaps I should give it another shot. I find the bracelet on the MM300 to be a challenge in general as it's heavy and I can't seem to get a good fit by adding/removing a link or adjusting the micro adjustment. I can get a good fit if I release the ratchet once notch, but I don't love the way it looks. I think a rubber strap is my best bet on that watch but I just really like the way it looks on the bracelet.Ryeguy wrote: ↑Tue Feb 07, 2023 8:11 amI agree. While I really like my MM300, the 62MAS reissues are just really easy daily wear watches.
I think one of the issues with MM300 bracelet is it has relatively long links. I was able to find a good fit using trial and error between adding / removing links and using the micro adjusts on the clasp, but I can see how not everyone is so lucky.
If the clasp on your MM200 is the same as on my 62MAS reissue, you should be able to swap them pretty easily. The clasps are exactly the same width. The MM300 is a tiny bit thicker than the standard Seiko diver's clasp, but only about 2mm by my measurement.
I'm not sure, however, you are going to gain too much extra adjust-ability though in doing the swap. The "standard" Seiko diver flip lock has that "wetsuit extension" thing on the 6 o'clock side of the clasp which adds length to that side of the bracelet. It pushes the entire clasp toward the 12 o'clock side.
When I hold the two clasps side by side and aligning them at the flip lock rivet, the standard Seiko diver's clasp is the same overall length as the MM300 clasp with the same number of micro adjustment holes.
Where you may gain comfort is the standard clasp has the hinge between the "wetsuit extension" bit and the flip lock, almost like a half bracelet link. The MM300 clasp is stiff across its entire length. I've heard of some people actually increasing the bend on a MM300 clasp a bit to make it conform a little better to their wrist. I'm lucky that my wrist are a bit more rectangular so the standard bend conforms to me OK. .
Bottom line, if you have the MM200 clasp handy, do the swap and see which one is more comfortable for you. No modification is needed and the only tool necessary is a toothpick. I didn't even have to add or remove a bracelet link when I did the swap from the standard clasp to the MM300 clasp on my 62MAS reissue.
- spring-diver
- Name: Shannon
Another interesting detail, the date wheel is textured to match the dial.Mr_Pacman wrote:That dial looks great and the strap will be very high quality. Much different than any other nato that sells for $20. Wonder how the black PVD would hold up over time?spring-diver wrote: ↑Sun Feb 05, 2023 6:34 pmSLA067
LE 600
https://www.fratellowatches.com/new-rel ... iver/#gref
That dial
- Name: James
That's just badass
Seiko Introduces a Pair of Solar Diver GMTs
the case measures 45mm in width, 13.2mm in thickness and a very long 51.8mm lug to lug. good for some of you meaty-wristed bastards out there who complain about all the 38-40mm watches coming out nowadays.
https://wornandwound.com/when-seiko-sum ... re-abroad/
- 59yukon01
- 1.21 gigawatts?!
^^^That's definitely a Sumo case.
I want to see that solar GMT in some other cases!
I have no need for GMT, but I’d definitely buy a Turdle with that movement.Bob1035 wrote:I want to see that solar GMT in some other cases!
Excellent work detective! 🧐spring-diver wrote: ↑Tue Feb 07, 2023 6:59 pmAnother interesting detail, the date wheel is textured to match the dial.Mr_Pacman wrote:That dial looks great and the strap will be very high quality. Much different than any other nato that sells for $20. Wonder how the black PVD would hold up over time?spring-diver wrote: ↑Sun Feb 05, 2023 6:34 pmSLA067
LE 600
That dial
Guys, have you seen Seiko's newest Speedtimer Mechanical Chronograph?
This watch, reference # SRQ045 has details like a 42.5mm black hard coated
stainless steel case, black matte sandblasted dial with red and white accents,
black calfskin leather strap, plus the Seiko 8R46 automatic chrono movement.
Just a few pictures...
Time and Watches along with Seiko as well for you...
https://timeandtidewatches.com/introduc ... ph-srq045/
https://www.seikowatches.com/us-en
I like it Tom, what about you? At 3,000 Euros it’s a bit steep but it’s sharp looking.AtomicTom wrote: ↑Thu Feb 09, 2023 1:02 pmGuys, have you seen Seiko's newest Speedtimer Mechanical Chronograph?
ezcheese wrote: ↑Thu Feb 09, 2023 2:45 pmI like it Tom, what about you? At 3,000 Euros it’s a bit steep but it’s sharp looking.AtomicTom wrote: ↑Thu Feb 09, 2023 1:02 pmGuys, have you seen Seiko's newest Speedtimer Mechanical Chronograph?
Yup, I definitely won’t be picking one up sir. But it is cool to see.
In situations like this I think a lot of people just look for a nice sporty
looking black PVD coated watch to scratch an itch a watch like this
might cause.
I’m with you, $3000 is a bit up there. And I honestly don’t get what
is behind the pricing. But it’s a nice looking watch thst’s for sure.
Something else very cool was hearing what you had to say, so thanks
so so much once again !!!
They have to charge extra for all the material in those pushers maybe?
You think those pushers are big? hehe
It was just a bit chilly on the photo shoot set.
[/quote]
[/quote]
Those aren’t pushers right guys?! They are space stations.
(Star Wars reference) ..It’s true though, they are pretty big no
doubt. Thanks a ton for making me, or us smile everyone !!!
Hey everyone, did you see these vintage inspired King Seikos?
These watches come with 37mm to 39mm stainless steel cases, as well as
bracelets, very eye-catching dials, the Seiko 6R55 And much much more.
Some pictures guys...
W&W and Seiko as well for you...
https://wornandwound.com/a-new-collecti ... niversary/
https://www.seikowatches.com/us-en/products/kingseiko
I wish those king seikos had better movements, but they are nice.
- jswing
- Name: Jeff
These new King Seikos look nice. The 37mm size of the previous model kept me from thinking too seriously about them, but 39 should be just about perfect. Could do without the 3 days text on the dial, but oh well.
- Henryj
- Bubblehead
- Name: Old guy
Not fer nuttin’ but Seiya also shows a black dial version on his website.gwells wrote: ↑Thu Feb 09, 2023 8:21 amSeiko Introduces a Pair of Solar Diver GMTs
Just seeing these new Seiko 5 Sports Field models in a new 36mm size.
How about you guys?
There look to be two black dialed versions, along with a beige dialed model.
All with 36.4mm brushed stainless steel cases, calibre 4R36 along with both
nato straps, stainless steel bracelets and more.
Some pictures everyone...
Monochrome Watches, along with Seiko with this and more...
https://monochrome-watches.com/introduc ... ecs-price/
How about you guys?
New auto GMTs.
Green #SPB381 #SBEJ009
Black #SPB383 #SBEJ011
Save the Ocean (4000 Pcs) #SBEJ013
Users browsing this forum: No registered users and 168 guests
