Similar to the models shows in another post here, there are many other ones that Seiko has been putting together with some wild and unusual looks.
Of all those, there are some that are actually cool, at least for me. One of them is the Brian May Seiko Limited Edition which was put together using a Seiko 5 with the newer case similar to the SKX. Of course these are pretty expensive watches compared to the regular models.
I was able to find a couple of these dials which were also expensive but very cool looking. Also for the first time I got these new models so I could check them out.
Seiko 5 with no rotating bezel, 40mm and 20mm lugs, usually SRPE models:
Seiko 5 models fun projects
Re: Seiko 5 models fun projects
Seiko 5 with rotating bezel, 42mm and 22mm lugs, same as SKX but push pull crown, this is essentially exactly the same as the one being sold by Seiko.
- manitoujoe
- Name: Mark
Those are cool! You make the coolest stuff.
Steve Martin
Steve Martin
Thank you Mark, the dials are very nice and it was fun...
Users browsing this forum: No registered users and 143 guests
