Farer Monopusher
Farer Monopusher
$1,995.00
Usually Farer does too much with color, but I like this one.
Re: Farer Monopusher
I’m a huge fan. If I didn’t get the Carnegie a few months back I’d snatch it. Maybe sell to buy this
That is very clean looking.
I really like that.
SPECIFICATIONS
CASE - 40.5mm diameter, 12.2mm depth (14.7mm to dome peak), 44mm lug-to lug, 42mm pin-to-pin
MATERIAL - 316L marine grade stainless steel
FINISH - Polished top bezel, brushed lug tops, harlequin pattern engraved flanks, polished bellytanker shaped case back with exhibition flat sapphire glass portal
INNER BEZEL - Raised telemetre bezel
DIAL - Matte black dial with polished steel train track hour markers infilled with natural white Super-LumiNova, silver white turned texture 'big-eye' bias cut minute sub-dial counter, seconds sub-dial set on dial surface, matching date at 6
HANDS - Polished steel mint green Super-LumiNova infill sword style hour/minute hands, sky blue split hand, teal and signal orange sub-dial counters
CROWN - Straight solid stainless steel, machined bronze inset cap featuring embossed Farer ‘A'
MONO-PUSHER - Capped recessed button in polished 316L stainless steel
GLASS - Double layer underside anti-reflective coating curved box cased sapphire crystal, flat sapphire exhibition glass on rear
STRAP - St Venere leather strap with 316L stainless steel buckle fastening
LUG- 20mm
WATER RESISTANT - 10ATM
MOVEMENT
Swiss Made Sellita SW510 MP Elaboré grade moment finished with heated blue screws and guilloché finishing on bridge. Bespoke Farer navy rotor and orange lettering
FUNCTIONS
Hours, minutes, 60 second chronograph, 30 minute counter at 3, small seconds at 9. Quick set date, hacking capability
JEWELS - 23
WINDING - Self-winding mechanism with ball bearing
POWER RESERVE - Up to 62 hours
MODERN HERITAGE
As well as having serious watchmaking heritage behind it, the SW510 MP is an up-to-the minute, self-winding movement with 23 jewels, running at 28’800 vibrations per hour (4 Hz). An Elaboré grade movement, adjusted in three positions (to minimise any effect of gravity on the balance wheel’s oscillation) with enhanced power reserve, delivering up to 62 hour power reserve. On closer inspection you'll see the custom finishing with beautifully heat-blued screws, guilloché detailing on the bridge and a custom navy blue turbine rotor design with striking orange branded lettering.
SPECIFICATIONS
LUG- 20mm
MOVEMENT
FUNCTIONS
JEWELS - 23
MODERN HERITAGE
I like it!
Ooohhhh, I really like this one.
Thanks for the specs, Matt
I like it too.
I might have missed it in Matt's specs, but it uses a Sellita SW510 chronograph movement, with custom finishing by Farer.
If this came out on Hodinkee it would already be sold out and on eBay for $5000
Thanks Matt.
i like it. even at $2k it seems pretty nice.
- gonzomantis
Very, very nice.
That is a definitely a looker Paul.
Farer does some really neat things with their watches
imho. They don’t seem content to just do the usual,
or ordinary. But rather do things to make their watches
extraordinary.
I mean from a distance, or at first glance these look
almost vintage. However, up close they really grab you
thanks to the refined design, as well as nice touches
of color.
Thanks so so much for the news, along with look !!!
extraordinary.
of color.
That’s hot! Love the knurled sides
Users browsing this forum: No registered users and 184 guests
